Vivianaors Posted June 21, 2013 Report Share Posted June 21, 2013 hi, I have a project and require communication between a ABB drive and V280 unitronics, where v280 is the master, anyone can help me or suggest how I start? thanks, pd. I have done this type of communication but with other brands, this brand only cut I made the flight program without communication inputs and outputs only analog and digital. Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted June 24, 2013 MVP 2014 Report Share Posted June 24, 2013 First place to start is to confirm the type of protocol that can be used with the drive. Is it Modbus? Then get the detailed user manuals for the drive communciations protocols. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted June 24, 2013 Report Share Posted June 24, 2013 You may start checking MODBUS IP examples under "Project examples/communication/Ethernet/Ethernet modbus ip". It shows how to use TCP mode, however I usually use UDP mode Quote Link to comment Share on other sites More sharing options...
Vivianaors Posted June 24, 2013 Author Report Share Posted June 24, 2013 thanks, I am using the example as a guide visilogic before i don't know how to configure the parameters that I want to read or write, now the problem is not as checkbook this communication is taking place. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted July 7, 2013 MVP 2023 Report Share Posted July 7, 2013 I recently interfaced with an ABB drive via Modbus IP. You'll need the ABB documentation on what the Modbus parameter addresses are. Did you get this problem solved? Joe T. Quote Link to comment Share on other sites More sharing options...
