Andreas Svensson Posted November 4, 2014 Report Share Posted November 4, 2014 A problem popped up with images on my V350. We have historically uploaded our applications from the SD card reader (in production). Now we face a new problem with images created by us. On the SD upload, we are missing some of these images. Seems to be only for button images. After uploading a project from the SD card, everyting seems to be ok except that none of the button images are loaded. All buttons with images set, will be green. To resolve the issue, we need to download an empty project on the V350 onboard serial port. Then download the "real" project again, this also via the serial port. All images are in place after this proceedure. What would be the difference between making a clone or clone + OS on an SD card compared with uploading the same project directly from the PC? Is my image library not complete when making the clone file? Regards Andreas Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted November 10, 2014 Report Share Posted November 10, 2014 Hello Andreas, When performing a clone+OS from SD it will download the projects and the selected operation system. If the images will not be completely downloaded please verify that the Boot and the BinLib are compatible with the selected operation system version. Please use the your current VisiLogic version and create new clone+OS for the SD. we recommend to use the latest VisiLogic V9.7.24 from our website. I hope it helps.. Quote Link to comment Share on other sites More sharing options...
icotenev Posted November 22, 2015 Report Share Posted November 22, 2015 Hello dear colleagues.I have a problem with V570 PLC.During the download of a new OS screen PLC became darker and communication was lost. Currently there are no communication in any port and the screen remains blank.I'll be very grateful if you could help me. Quote Link to comment Share on other sites More sharing options...
EduMarg Posted November 22, 2015 Report Share Posted November 22, 2015 Hello icotenev. If you reboot the PLC do you have communication with the PLC? Please also try rebooting the PLC while pressing the screen. The PLC will start in boot mode and you will see a counter. Press the screen once more so the counter will stop. Download the BIN lib only and then reboot the PLC. Then try communicating and download the O/S. Please let us know if this helps. Quote Link to comment Share on other sites More sharing options...
icotenev Posted November 22, 2015 Report Share Posted November 22, 2015 I have already tried but got only a black screen without communication Quote Link to comment Share on other sites More sharing options...
TozoM8 Posted November 23, 2015 Report Share Posted November 23, 2015 Are you using the USB port. I found them unreliable. I have 14 Unitronics PLCs at work and the usb port on 3 of them stopped working. Bought a usb to serial converter and use the serial port for downloading. No more issues. 1 Quote Link to comment Share on other sites More sharing options...
