Exxiter Posted August 13, 2010 Report Share Posted August 13, 2010 I use DataXport for a long time without problems on my old PC with Windows XP SP3 and Excel 2000. Now I bought a brand-new PC from Acer with Windows XP SP3 and Office 2010 (Excel 2010). After the new installation of DataXport V3.0.1 I receive the runtime error 429 "activeX component can't create object". For the first time after receiving data from the PLC. After the first time at once by calling the PLC. I tried to solve the problems with suggestions from the old forum. e.g. re-installation of DataXport didn't work. I checked the MDAC-version (V2.8) from Microsoft, but no problems are detected. Do you have any experiences with Excel 2010 and DataXport? Do you have any ideas to solve this problem? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted September 6, 2010 Report Share Posted September 6, 2010 Hello, We just checked DataXport with Excel 2010 and it's working fine without the mentioned error. Did the error message appears immediately after openning DataXport? Or, after some action? (Call,Export...) This error may occur because the ActiveX or COM DLL being accessed is not registered on the system. Please try as follow: Install the latest Microsoft .NET Framework Reboot and delete and files in the TEMP folder on your PC. These are usually located in C:\Windows\Temp and in the %temp% environment variable. Reinstall the component package that includes the DLL being accessed. This will register the DLL. Quote Link to comment Share on other sites More sharing options...
Exxiter Posted October 6, 2010 Author Report Share Posted October 6, 2010 Hello, the error message appears immediately every time by starting a force call or starting a scheduled call. Now, I have installed the latest .NET Framework (version 4) from Microsoft, deleted the files in the TEMP-folders and reinstalled the DataXport software. But with the same result. I always get the runtime error 429 "activeX component can't create object". Do you suggest to reinstall other Unitronics products? I use on the same PC the VisiLogic software and your UnCmDrv1.dll file with a Visual Basic 6 application. But neither VisiLogic, nor the Visual Basic application have any problems. Everything works fine, except DataXport. Do you have any further suggestions? Or can you tell me, which DLL files should be replaced or reinstalled or changed in any way? Quote Link to comment Share on other sites More sharing options...
Saragani Posted October 11, 2010 Report Share Posted October 11, 2010 Hi, it might be hard guessing what is wrong. If you accept, I can connect to your computer using TeamViewer and debug the code in order to find the problem. Quote Link to comment Share on other sites More sharing options...
JamesWight Posted December 1, 2011 Report Share Posted December 1, 2011 Hello, Runtime error 429: “ActiveX component can’t create object” Here is a solution to this error: Reinstall Windows Script Repair Windows Script File Information in Registry Reregister Concerning File Reset Internet Explorer Settings Restore your Computer Repair System Files i also faced this error many times but i fixed it, i also got some help from this article error429 , hope someone might get help from this article. 1 Quote Link to comment Share on other sites More sharing options...
SophieTucker414op Posted April 28, 2018 Report Share Posted April 28, 2018 Reregister the File There have been instances when a 429 error is accompanied by a particular file name. In this situation it could be the case that the specified file is not properly registered in your Windows registry. Thus, reregistering this file may be all that is required to fix this problem. Anyway, you can do this method check out on this URL https://www.errorsolutions.tech/error/runtime-error-429/ Quote Link to comment Share on other sites More sharing options...
