Meetto
Screen with password
5 posts in this topic
Hi all,
 I 'm trying to make a screen with password access in UniStream. How can it be achieved?
0
Hopefully you've already figured this out, but just in case you haven't....
If you want to prevent other programmers from seeing a particular screen configuration, you can right click on the screen name(in the Solution Explorer), then select "Password Protect"
If you want to prevent unauthorized access to the screen during operation, you can assign a button on another screen("Main Menu", for example).
Then, in the Properties Dialog box for the button, add a new "Load Screen" Action, then set the User Access property.
In the Solution Explore, use the "User Access Control" to configure the different levels of access, as your application requires.
I apologize for not being more detailed, but I am also a new to the UniLogic platform and just started looking into the whole password protection/user access system.
The more I learn, the more I like!
2
 Hello there :-)
The Help file for UniLogic does contain information on how to use passwords to ensure security--check out the attached screen capture.
2
Dear Dave and Clara,
thank you for the help.
I sorted the problem. Bit late to reply. sorry.
0
Register a new account
Sign in
