hotwires Posted February 19, 2017 Report Share Posted February 19, 2017 Dear Community, How do I see two (or three) trend curves at the same time as seen in Visilogic? Thanks All! Sincerely, Hotwires Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted February 19, 2017 Report Share Posted February 19, 2017 Hi Define a Data Sampler with multiple feeds, as explained in the Help topic Trends. The feeds show up as curves. (Use the topic HE: Trends, NOT Creating a Trend graph. While I was checking this, I discovered a bug in the Help file) There is also a how-to video. Quote Link to comment Share on other sites More sharing options...
hotwires Posted February 19, 2017 Author Report Share Posted February 19, 2017 Cara, I have the data samplers established, have FIFO trends on HMI, I seem the have all the parameters set. Having two issues: It only seems to display one curve at a time. Other issue is the curve stays at zero even when the sampled variable is 90 (scale 0 to 100). I read thru the help before posting last night. See example below. Trying to create it's parallel is UniLogic. Quote Link to comment Share on other sites More sharing options...
hotwires Posted February 20, 2017 Author Report Share Posted February 20, 2017 Still no success with trends displaying on a running basis. Watched videos and read the help twice, spinning my wheels. Quote Link to comment Share on other sites More sharing options...
EduMarg Posted February 20, 2017 Report Share Posted February 20, 2017 Hi, In order to better help you: Will it be possible to send us the application to support@unitronics.com for review? Can you please tell us on the properties windows/trend curve list option, when the trend curves configuration window is open: Is the option "is visible" selected for all curves? What are the values for Max and Min columns? 3. Can you please tell us what version of UniLogic and Bin files are you using?\ Please note that the latest version of UniLogic is V1.18.60 and BIN files 1.18.19. We recommend to install and use this versions. I use the attached example, I change the trend on the HMI to FIFO and had no issues viewing the 3 curves at the same time. But remember that only one of them will have the focus and that is the one that will have the title on the upper part and the correct units on the X axis. UniStream_070_Data_Sampling_And_Trend.ulpr 1 Quote Link to comment Share on other sites More sharing options...
hotwires Posted February 21, 2017 Author Report Share Posted February 21, 2017 sent files and version to support. I hope this isn't just something I'm doing wrong. Regardless I'll be happy to see resolve. Thanks. Quote Link to comment Share on other sites More sharing options...
