Marco Brombacher
Store Integer does not work
6 posts in this topic
Hi,
I want to store the int16 value of an analoge input into a global tag int16. The value of the input is correct but the Store Integer function does not work. The value of the global tag remains 0. I tried to find info on the subject without succes. Can anyone help me?
This is the view in online mode...
0
Can you link an HMI numeric variable to the Control Stick pos?
Can you tell me if the System Tag Execution -> Scan Count incrementing?
Do you see any "CPU Error" message on the Panel?
0
Also, do a search on the tag, "Control stick pos..." to make sure you're not assigning it a value anywhere else in the program.
1
Is this in the main routine?      or in a subroutine?   is the subroutine being called?
1
Turned out I didn't call the  function.  Your input helped me solve the puzzle. Thank you!!!
1
Thanks for letting us know you got it solved.
1
Register a new account
Sign in
