Andreas Posted June 11, 2018 Report Share Posted June 11, 2018 Hi, After downgrading my plc (7" UniStream) from UniLogic 1.23.25 to Unilogic 1.18.60 i got this error. I have tried to upgrade it to Unilogic 1.23.25 again but nothing helps. Here is an image of the error message: Please help. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Guy Sela Posted June 11, 2018 Report Share Posted June 11, 2018 Hi Andreas, I have sent you a private message with some instructions in order to solve this issue. Quote Link to comment Share on other sites More sharing options...
Diego7793 Posted October 6, 2020 Report Share Posted October 6, 2020 Hi, I have the same problem Can you pass me the solve please Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 7, 2020 Report Share Posted October 7, 2020 Diego7793, Please send your request to support@unitronics.com Add PLC serial number from Panel and PLC model. Support will send you instructions. *Instructions are not published, as are dependent of number of conditions (PLC model, UniLogic version, Firmware version, etc.). Quote Link to comment Share on other sites More sharing options...
Fil Posted October 27, 2023 Report Share Posted October 27, 2023 Hi, I have the same issue. I bought new USP 070 B10 (old one is damaged) and downgraded FW to 1.32.98. Could you pls help me? Thanks Filip Quote Link to comment Share on other sites More sharing options...
AlexUT Posted October 29, 2023 Report Share Posted October 29, 2023 Please send your request to support@unitronics.com Add PLC serial number from Panel and PLC model. Support will send you instructions. *Instructions are not published, as are dependent of number of conditions (PLC model, UniLogic version, Firmware version, etc.). Quote Link to comment Share on other sites More sharing options...
