SoCalJim Posted October 10, 2018 Report Share Posted October 10, 2018 I have YABE running on my PC and it does not see my GW-BAC1 but it does see other BACnet devices. Should YABE see a standalone GW-BAC1 or does the GW-BAC1 need to be controlled by an HMI to become active? Here's the config details: UniBACnet Configurator Protocol: BACnet IP Port 47808 One Device Instance: 0 with name Node1 One Descriptor: Analog Input Modbus connection: Modbus IP Quote Link to comment Share on other sites More sharing options...
SoCalJim Posted October 16, 2018 Author Report Share Posted October 16, 2018 I am trying to control a BACnet device via a GW-BAC1 gateway but it doesn't work. The device has 8 digital outputs and 8 digital inputs. See the attached YABE display. I am just trying to control the first digital output. Does any of the information in the YABE display go into the GW-BAC1 config file? Here's my config file: //================================================================================ // // Common Information // Bridge Title CN0864 Unitronics v1.00a //================================================================================ // // Data Arrays // Data_Arrays Data_Array_Name, Data_Array_Format, Data_Array_Length DA_BO_, Bit, 1 //================================================================================ // // Client Side Connections // Connections Adapter, Protocol, IP_Port N1, Bacnet_IP, 47808 //================================================================================ // // Client Side Nodes // Nodes Node_Name, Node_ID, Protocol, Adapter Node1, 0, Bacnet_IP, N1 //================================================================================ // // Client Side Map Descriptors // Map_Descriptors Map_Descriptor_Name, Data_Array_Name, Data_Array_Offset, Function, Node_Name, Object_Type, Object_Instance, Property, Scan_Interval BinaryOutput, DA_BO_, 0, Wrbc, Node1, BO, 0, Present_Value, 2s //================================================================================ // // Server Side Connections // Connections Adapter, Protocol N1, Modbus/TCP //================================================================================ // // Server Side Nodes // Nodes Node_Name, Node_ID, Protocol, Address_Type Unitronics_Modbus_Node, 255, Modbus/TCP, ADU //================================================================================ // // Map Descriptors // Map_Descriptors Map_Descriptor_Name, Data_Array_Name, Data_Array_Offset, Function, Node_Name, Address, Length, Data_Type SMD_DA_BO__1, DA_BO_, 0, Passive, Unitronics_Modbus_Node, 1, 1, Coil Quote Link to comment Share on other sites More sharing options...
NahumS Posted January 8, 2019 Report Share Posted January 8, 2019 Hello SoCalJIm, I do not understand what are you trying to achieve, if you have our GW-BAC1, it need to have a controller to control it. BACnet will not configure itself. you have to follow the procedure how install it properly. the User Guide is attached. Good Luck. gw-bac1.pdf Quote Link to comment Share on other sites More sharing options...
