RICARDO MARRERO Posted January 28, 2019 Report Share Posted January 28, 2019 Good Morning guys , please could you support to us in the following questions? We have installed 120-22-R2C controller just in my computer because we have not yet received the controller. Version is 9.8.79 build 0 Beta and we have some questions: 1 - For this controller and this version , could we configure from ladder to load the startup display and the main display after booting the controller, we could do that with SB2 bit , Timer, load display , and reset . 2- We have a question regarding to download command , we are going to command a butterfly valve through On Off actuator , we have seen we have some download commands , they are Download , Stop Download Run , Stop Download Reset , we need to know , what does allow to us to download the change to the controller without changing the current command to the valve. Thanks for your support Besta Regards Ricardo Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted January 28, 2019 MVP 2023 Report Share Posted January 28, 2019 1 - The Start-Up Display will load automatically upon boot up. You can then load any other display you wish at any time via ladder or via the Link & Jumps tab on the display using screen buttons, timers, or any other logic you wish. 2 - This is from the Help file. It's an excellent resource. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 28, 2019 MVP 2023 Report Share Posted January 28, 2019 Duplicate post - I'll delete this in a couple days Joe T. Quote Link to comment Share on other sites More sharing options...
