Analog input Stops reading in 2 channels randomly
Vprakatoor
Hi
I have a Unistream with the following modules and positions
UID-1600 @ 0    Di module
UID-0016R @ 1 DO relay module
UID-0402N @ 2 AI/AO module
UID-0402N @ 3 AI/AO module
I dont have any analog outputs on the UID-0402N modules, on one of the 0402N the 4-20ma signal coming in on channel 4 from a level transmitter randomly reads 0% for 2 mins and then comes back  to actual level after that for 2 more minutes and then goes back to 0 for 2 mins and so on. while this is happening the display on the transmitter reads correct the whole time and the 4-20ma on the terminal blocks read fine(checked with meter). If i power cycle the UNIStream the problem gets fixed for a few days and then it starts up again. any help on this would be greatly appretiated.
