MVP 2023 Joe Tauser Posted February 7 MVP 2023 Report Share Posted February 7 When you update the OS on a Unistream the screen flashes but you have no idea as to the progress of the update. I've been watching it flash for 45 minutes and I don't know if I should wait a little longer or if the PLC has gone bye-bye. Is it possible to make the update screen more verbose with a progress bar and other status messages? Joe T. 1 Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 8 Report Share Posted February 8 45 minutes is a lot of time. What PLC model is it, USP or US5/7? If it didn't finish after that time, then I think that something went wrong during the upgrade process, but you should be able to recover the PLC (Depending on the Model) @NoamM Please reply. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted February 10 Author MVP 2023 Report Share Posted February 10 The model is a USP-156-B10. We did it using a USB flash drive. We had other things to do so we let it keep flashing. The update took an hour, but it did finish. This was from version 1.32.98 to 1.34.195. Should we have done an interim update to 1.33? Joe T. Quote Link to comment Share on other sites More sharing options...
NoamM Posted February 11 Report Share Posted February 11 Hi Joe Tauser, Should we have done an interim update to 1.33? No Open a ticket on Unitronics "Help center" at https://support.unitronics.com/index.php the Support team have a wider view on Upgrade issues, I di not encountered such report. Quote Link to comment Share on other sites More sharing options...
