External Moderators Nacho Posted October 14, 2011 External Moderators Report Share Posted October 14, 2011 What does "12Subscript out of range" mean? It's the error message I get when start Visilogic. And the most important, how can I solve this error without installing Visilogic again? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted October 17, 2011 Report Share Posted October 17, 2011 Hello, DidVisiLogic was worked before properly? If yes, what was changed? Doesyour Windows is 32bit or 64bit? Youcan also try to reinstall VisiLogic as below and check if the problem remains: ForXP Please do the following: Backup your application files. Uninstall VisiLogic. Erase the “Unitronics” folder from- C:\Program Files Erase the “Unitronics” folder from- C:\Program Files\Common Files. Install VisiLogic again. I hope it helps! Quote Link to comment Share on other sites More sharing options...
External Moderators Nacho Posted October 17, 2011 Author External Moderators Report Share Posted October 17, 2011 Windows 7 64 bits, it was working properly up to the PC switch off of a sudden. I reinstalled Visilogic erasing folders and now it work again. Is there any file we can edit to avoid Visilogic try to recover the failed application? Quote Link to comment Share on other sites More sharing options...
Emil Posted October 18, 2011 Report Share Posted October 18, 2011 Hi Nacho, not exactly, but you can go to C:\Program files \Unitronics\Unitronics VisiLogic_C\Data\DB and to delete thhe file Curent_OPLC.udb, if exists. Quote Link to comment Share on other sites More sharing options...
colmheneghan Posted February 4, 2013 Report Share Posted February 4, 2013 for windows xp when you are uninstalling the unitronics software can you not fix the problem so that it deletes the 2 unitronics folders.would make sense! Quote Link to comment Share on other sites More sharing options...
