URGENT! I/O bus error [Code 0]
Hi everyone!
I have an urgent issue to solve 🫤
In one of my working project a new issue has appeared with the following error message:
After a reboot the PLC working fine for about 10-15 minutes and the error appears again. Let me show the PLC I/O configuration :
I have just replaced the UAG-XKP300 (beetween the PLC and first row IOs) with a brand new one. Started the machine and it works fine...for about 15-20 minutes. The same error appears!
I've checked the IOs and all of it blinks red slowly, except one of its! UID-0808THS (number #18 IO modul, after the second UAG-XKP300) blinks red rapidly.
Now I try to change the second UAG with a new one.
But before error appears again, does anybody have any idea what to do? Try to change CPU ? What does error 0 mean?
Thank you! Unfortunately it is really important and should solve quickly
Best regard,
Balazs
I'd create new projects and test each I/O section.
Create one that only has the original block of I/O and test it.
Create another one that just has the original block and the 2nd (long) block of I/O.
Create a third one that has the original block and the 3rd (short) block of I/O.
That should tell you if each piece is operational and it shouldn't take that long to do it.
  • 1 month later...
Balazs,
Were you able to resolve this?  I am showing the same reoccurring error on one of our PLC s
Running firmware 1.36_63
Not nearly as many cards as your program
Wondering if it ended up being hardware or software related
Thanks
Register a new account
Sign in
Important Information
