Fotonic Posted April 20 Report Share Posted April 20 Hi all, in Unilogic there's the option to add a pop-up window on a button press, that window is customizable but only within some predefined models. I'd like to have a custom pop-up window to open for some specific tasks (example a motor control or a setpoint definition for an analog instrument), is there any hope that this will be considered by Unitronics team? On some other PLC brands there is already this functionality, an HMI screen can be defined to open as a pop-up over the current displayed one. Thanks, regards. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted April 20 Report Share Posted April 20 This task can be accomplished by use of "HMI Custom controls" The advantage: you design it just one time and re-use it as many times as needed. Quote Link to comment Share on other sites More sharing options...
Fotonic Posted April 21 Author Report Share Posted April 21 20 hours ago, Gabriel Franco said: This task can be accomplished by use of "HMI Custom controls" The advantage: you design it just one time and re-use it as many times as needed. Please be more specific, I don't understand the correct way to achieve this using custom controls. I've created a custom control, a simple window with 3 buttons, now what? I don't see any option to 'attach' this custom control window to a button, how do I make it appear on button press? Does it need to be positioned over the HMI screen and then use a bit to hide/unhide the custom control at the press of the button? If there is another way to do this please explain. Thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted April 21 MVP 2023 Report Share Posted April 21 I did some experimenting in UniLogic with this question and reached the following conclusions: 1. You can't change the size of the HMI screen. Therefore there is no "pop-up" window functionality at this time. You can't drop a Custom Control onto a new display that is only the size of the Custom Control. 2. When you press a button one of the options available is "Message Box". This is like a Visual Basic dialog box asking a basic Yes/No question. You can't really change it. 3. You can add a Custom Control to it's own Layer, and then play with the Visibility property to make it appear and disappear. Those are my observations. If anyone has concrete experience on this feel free to chime in. Joe T. Quote Link to comment Share on other sites More sharing options...
Fotonic Posted April 21 Author Report Share Posted April 21 1 hour ago, Joe Tauser said: I did some experimenting in UniLogic with this question and reached the following conclusions: 1. You can't change the size of the HMI screen. Therefore there is no "pop-up" window functionality at this time. You can't drop a Custom Control onto a new display that is only the size of the Custom Control. 2. When you press a button one of the options available is "Message Box". This is like a Visual Basic dialog box asking a basic Yes/No question. You can't really change it. 3. You can add a Custom Control to it's own Layer, and then play with the Visibility property to make it appear and disappear. Those are my observations. If anyone has concrete experience on this feel free to chime in. Joe T. I think it should be of minor effort for Unitronics staff to introduce the action to load a custom control on a button press. Custom control window could be loaded centered on screen press coordinates and in case moved to avoid falling outside of the HMI area. Maybe introduce a new action to close/hide the custom control window opened this way. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted April 21 Report Share Posted April 21 I designed this Custom Control to control reversible motor. It has motor name, modes (O, P, M) , fwd start, rev start, alarm messages, alarm reset, interlocks status, motor status, close button. Every part is attached to a tag (part of a struct defined to control a motor). e.g, up button: . Then, add the custom control to the screen (in this step, you cannot modify its size), set the specific motor tag (e.g. input conveyor #1) and use a tag visibility to show the control. Set that tag when pressing the device you want to control. Quote Link to comment Share on other sites More sharing options...
Fotonic Posted April 22 Author Report Share Posted April 22 I see, thanks. So if I need to add a pop-up window on every motor on a synoptic screen I'll have to place all the custom controls on screen and associate tags for animation/logic. In this case, to avoid an over crowded HMI screen in the Unilogic editor what's the best strategy? Place all the pop-ups on a dedicated layer as suggested by @Joe Tauser to show/hide on necessity while editing the regular HMI elements? Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted April 22 Report Share Posted April 22 28 minutes ago, Fotonic said: So if I need to add a pop-up window on every motor on a synoptic screen I'll have to place all the custom controls on screen and associate tags for animation/logic. Correct. 28 minutes ago, Fotonic said: In this case, to avoid an over crowded HMI screen in the Unilogic editor what's the best strategy? Place all the pop-ups on a dedicated layer as suggested by @Joe Tauser to show/hide on necessity while editing the regular HMI elements? I place all the controls stacked on top of each other. By pressing the motor image (or the button or whatever you use to pop-up the control), reset all visibility tags and set the desired one. Quote Link to comment Share on other sites More sharing options...
Fotonic Posted April 22 Author Report Share Posted April 22 Yes, it's clear how it works on the PLC at runtime, I was referring to the editor, how to manage all the pop-up windows since they'll be placed over other HMI elements (at least in my case) and in the Unilogic editor that would cause some trouble in case the underneath HMI elements need to be accessed for editing. I have made a quick test and placing pop-ups on a dedicated layer seems to be a nice practice, if that layer is hidded then the "regular" HMI screen is all accessible for editing. Said so, this solution is a workaround for my initial quesion, I still hope that Unilogic staff will introduce native supporto for pop-ups one day... Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted April 22 Report Share Posted April 22 Layers: good idea, I haven´t used them. Other option: right-click the element and z-order it Quote Link to comment Share on other sites More sharing options...
walle Posted April 23 Report Share Posted April 23 14 hours ago, Fotonic said: how to manage all the pop-up windows since they'll be placed over other HMI elements (at least in my case) and in the Unilogic editor that would cause some trouble in case the underneath HMI elements need to be accessed for editing. I have a lot of instances with overlapped elements / graphics where hide visibility and pop up graphics are used throughout program depending on state / button presses Right click and use the send to back / bring to front I find easiest to work when using layers of elements Also can copy top element delete, work on bottom element and paste deleted one back when your done I find sometimes Copy / Paste and a couple blank HMI Editing pages is useful in keeping all elements in proper location for building and troubleshooting deleting top layered elements Copy / Paste some more and mesh it back up together Sometimes using coordinates to mark exact location of elements if you want to move something out of the way and place it back later All of this is easy when its your project and you're the builder, but I do see this being a bit of a pain for the next person dealing with hidden elements in some one else's program (but that's what "find tag" is used for) Quote Link to comment Share on other sites More sharing options...
Saragani Posted April 24 Report Share Posted April 24 Why aren't you using Layers? You can hide an entire layer while editing the HMI, so you won't have to send to back or bring to front. Quote Link to comment Share on other sites More sharing options...
walle Posted April 25 Report Share Posted April 25 On 4/24/2024 at 1:31 AM, Saragani said: Why aren't you using Layers? You can hide an entire layer while editing the HMI, so you won't have to send to back or bring to front. For me, layers introduce another variable to need to keep track of when editing Also, I would now want to name all elements in the title section to keep the layer section organized I keep all my elements titles at default (button 6 / fixed text 14 / binary image variable 4 / etc.) I can see the benefit of using layers depending on the page being created, I mean it would keep all elements better organized Most of my HMI pages don't have enough overlapping images to justify setting layers vs. send to back / bring to front I may try using layers going forward at some point for a screen with lots of overlapping elements Quote Link to comment Share on other sites More sharing options...
