JohnnyB Posted November 5, 2011 Report Share Posted November 5, 2011 Hi Guys I create a code with 25 lines. I need use the same code for more 138 inputs. Is possible use all codes in main routine ? - I try view the size off program but, visilogic show only in color´s bar. That accord of size show in bar´s color is possible. I don´t find a way for view size off program in Bit´s, Bit´s or other information. I use V130, Visilogic 9.3.1. Good weekend for all. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 6, 2011 MVP 2021 Report Share Posted November 6, 2011 The thought of 3,450 lines of code makes my head hurt- really bad. Is there a reason why you can't use indirect addressing in this application? Is the response time very critical? Joe T. Quote Link to comment Share on other sites More sharing options...
Emil Posted November 6, 2011 Report Share Posted November 6, 2011 In any case the max nets in one sub is 255. There are limitations in the volume of the code too. Writing in one sub is quite not possible. And - I don't see any advantage to od so. Disadvantages - how much you want? In such project, the best solution is to make one "general" subroutine and in a Data table to keep the real addresses. This will make programming way easier and elegant. There is relevant example in VisiLogic. Quote Link to comment Share on other sites More sharing options...
Damian Posted November 6, 2011 Report Share Posted November 6, 2011 Agree with Joe and Emil. If you have to do it 138 times.................. write it once, debug it once. You can use indirect addressing to carefully organized operand ranges, or data tables. With 138 operations, the data tables might be a little slow, but would be easier to deal with. If you have a lot of timers, you might want to build your own based of the internal clocks rather than the built in timers. Quote Link to comment Share on other sites More sharing options...
JohnnyB Posted November 6, 2011 Author Report Share Posted November 6, 2011 Mr Joe, Emil and Damian, thanks for response. My application is pulse counter. I use a V130-33-t38 , 8 modules IO-DI16 and 1 Ex-A1. Joe, the time is not critical. I calculate, max 2, 3 pulses per minute for each input. If i say, the code for one input have 20 lines. These lines, 11 are routines that will only be activated under specific conditions. If this happens, the main routine will 1242 lines with 138 sub with approx 9 lines each. These values are problem ? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted November 7, 2011 MVP 2021 Report Share Posted November 7, 2011 Have you written the code for one input yet? Can you post it? Joe T. Quote Link to comment Share on other sites More sharing options...
