mjarvas Posted September 11 Report Share Posted September 11 Hi, I have just upgraded to the latest version of UniLogic 1.38.64. Now if I click on any project file (updated or not updated .ulpr) it starts the Windows Installer, see screenshot below. It progresses through then it stops with a message. So far all the versions started the Unilogic software properly with opening the project. I can still open the project properly if I start the Unilogic and open it from there. During the upgrade I chose to keep the old version. The system OS is Windows 10 Pro. Is it a known issue? Any idea how I could fix this bug? Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted September 11 MVP 2023 Report Share Posted September 11 Please send this question to support@unitronics.com Link to comment Share on other sites More sharing options...
mjarvas Posted September 11 Author Report Share Posted September 11 I have just sent it. Link to comment Share on other sites More sharing options...
MVP 2023 Ausman Posted September 12 MVP 2023 Report Share Posted September 12 Have you tried checking the file association is correct, by looking at "Open with" from right click on the .ulpr file. Even if it appears correct, change it to something else, and then force it back to what it should be. Do this action with a copy of one of your .ulpr files, not the original. But for this to happen does appear to indicate something went wrong during the install. If this fixes it, then tell support anyway. If not, see what they say! cheers, Aus Link to comment Share on other sites More sharing options...
