pascal Posted May 18, 2012 Report Share Posted May 18, 2012 Is it possible to backup the user application trough software ? - without resetting the PLC ? I forgot to do this when I was at my client's house and now I'm afraid when he has a power failure, the program will be lost. I can access his controller via the internet, but I don't want a reset of the controller. I know you can do this when you are in info mode, but info mode is not accesible via the vision software. thanks Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 18, 2012 MVP 2021 Report Share Posted May 18, 2012 You can upload the project without bothering the PLC only if you selected "Download and Burn" when you downloaded it. Otherwise you are out of luck. A power failure will not cause loss of the program. Joe T. Quote Link to comment Share on other sites More sharing options...
Vidmas30 Posted May 19, 2012 Report Share Posted May 19, 2012 Hi, As Joe said "A power failure will not cause loss of the program." Just wanted to add - if the battery is installed, otherwise it will Quote Link to comment Share on other sites More sharing options...
