Guest Bill Posted November 27, 2012 Report Share Posted November 27, 2012 I just got a new laptop with Windows 8 on it. Is Remote operator compatible? Link to comment Share on other sites More sharing options...
Saragani Posted November 27, 2012 Report Share Posted November 27, 2012 Is it Windows 8/ Windows 8 Pro or Windows 8 RT? It should work on Windows 8 (or Windows 8 Pro), but it might fail because of administration rights (So you might wanna disable UAC notifications and run Remote Operator as Administrator... Please note that on Windows 8, even though you disable the UAC and you are an Administrator, some programs will not run correctly if you don't run it as Administrator) Link to comment Share on other sites More sharing options...
tantalean Posted September 14, 2013 Report Share Posted September 14, 2013 Does VisiLogic 9.5 runs or is suported on Windows Server 2008 32bits? I got many errors installing and now running it. I just completed a "Hello" progroma. Maybe Visilogic isn't meant for Windows Server (2008) and that is the reason. Please, Help. Link to comment Share on other sites More sharing options...
Jerin Posted October 21, 2013 Report Share Posted October 21, 2013 I just got a new laptop with Windows 8 on it. Is Remote operator compatible? Remote operator is compatible and working fine. But Couldn't communicate through Data export. Link to comment Share on other sites More sharing options...
R.Mozes Posted October 22, 2013 Report Share Posted October 22, 2013 Hi, Save the setup file on your desktop and make sure that the installation file is not blocked (Right click on the file>Properties) If yes, just click on the unblock button and then install the software. Then: Go to the properties of DataXport shortcut and under compatibility ticked verify the Privilege Level “Run this program as an administrator”. I hope it helps… Link to comment Share on other sites More sharing options...
