markofdiego Posted December 28, 2012 Report Share Posted December 28, 2012 I am building an application that I am using the binary image/ switch on. I have a lot of these as I am using them as status indicators for my IO. The problem is that when I do a download I get a warning for every one of these the states the font can't be found. I have not option to choose a font. I have this same problem with a few of my buttons. Is there a work around or is there someting that I am missing? Quote Link to comment Share on other sites More sharing options...
Walkerok Posted December 31, 2012 Report Share Posted December 31, 2012 Is it possible for you to put a copy of your program on the post? I do the same thing you do on most of my touch screen programs where I put binay images for an easy IO check and I have never recieved a message like this, but I would be willing to examine your program to see if I can figure anything out. Keith Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 31, 2012 MVP 2023 Report Share Posted December 31, 2012 Two suggestions, as this error really can't happen under normal circumstances. 1) Re-check to confirm what the warning is referring to. Visilogic warnings can often be a bit misleading and can sometimes refer to something else and fool you, particularly HMI warnings when there are many elements on the screen. 2) If it turns out that the warning really is for the font on a binary image switch, then you might want to consider re-installing Visilogic. Something is seriously wrong. Quote Link to comment Share on other sites More sharing options...
markofdiego Posted January 2, 2013 Author Report Share Posted January 2, 2013 I would agree that there is something seriously wrong. I also have Visiologics installed on my laptop and get the same warnings. If I copy the screen into a new project there are no warnings. But when I do this Visiologic gives me a ton of crash reports. Quote Link to comment Share on other sites More sharing options...
Saragani Posted January 2, 2013 Report Share Posted January 2, 2013 Please either attach the vlp here, or contact the support through email with the vlp attached. The R&D can easily find the problem. Please also provide information about the version of Visilogic you are using. Quote Link to comment Share on other sites More sharing options...
markofdiego Posted January 2, 2013 Author Report Share Posted January 2, 2013 I have contacted support and they are working on it now. Seems to be a corrupted program. Quote Link to comment Share on other sites More sharing options...
