Hy all,
I am new around here so big cheers to every one...
I have problem with connecting to my plc v1020 via ethenrnet port. I am using v200-19 ET1 snap in modul.
I programmed it correctly and i can ping my Plc, but when i try to connect with him in visio logic or by my aplication i get comunication error.
In visio is standard communication error....Both devices are new and i am the first user.
Can anybody help me??
Thank You very much
Thank you for answer... last night about 1AM 0'clock I solved the problem. I used socket 20257 becasue 20256 was in use (I progamed in PLC 20256 to be used ?!?), and I must use start bit to initialize network. It isnt like in webinars :)
Another problem I have is with readWrite function for reading MF registers for my SCADA program which i progamed in C#. I have examples for MI MB nad other Registers, what's the form for reading and writing in MF registers?
Thank you alot for help.
I can if need explaine more how I solved the problem.
- Make sure PC is on the same subnet as the PLC address.
- Use socket 1, port 20256, at least initially until you work out all your connection issues.
- Some PC firewalls can get stubborn and will want you to be on the 192.168.1.xxx subnet - try that (on both PC & PLC) if you aren't already.
- Check your cables. You need a crossover cable unless you're using an ethernet switch.
- Check your System Bits 141-150 to confirm that the ethernet card is present, initialized, socket initialized, etc.
