emer alexander Posted June 20, 2013 Report Share Posted June 20, 2013 descargue un proyecto en una versión diferente a la que tenia el v570 (comprado hace 36 meses), borre el o/s del plc para instalar el nuevo o/s, pero ya no completa la instalación y la pantalla quedo en negro. tampoco puedo acceder al sistema de información oprimiendo la pantalla. e intentado descargar el o/s en varias versiones del visilogic pero tampoco me a dado resultado. alguien me podria ayudar. Quote Link to comment Share on other sites More sharing options...
Gabriel Franco Posted June 21, 2013 Report Share Posted June 21, 2013 Check this link: Quote Link to comment Share on other sites More sharing options...
Jorge Luis Posted June 28, 2022 Report Share Posted June 28, 2022 Buenos días quiciera saber si me pueden ayudar ..tengo un problema quise cargar un nuevo programa a mi plc unitronics v350 y al momento de hacer la descarga me pide hacer la actualización del software...se realizo y se pudo con la pantalla negra y un pitillo ...pero en mi.laptop tengo comunicación aun Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 6, 2022 MVP 2021 Report Share Posted July 6, 2022 Translation - Good morning, I would like to know if you can help me... I have a problem. I wanted to upload a new program to my Unitronics v350 plc and when I downloaded it, it asked me to update the software... It was done and it was possible with the black screen and a cigarette... but on my laptop I still have communication Did you "Init and Reset" the PLC after you updated the O/S? Joe T. Quote Link to comment Share on other sites More sharing options...
DanT Posted July 8, 2022 Report Share Posted July 8, 2022 Hi; You probably solved the issue by now, but ( and for others ) : In VisiLogic, : Open Connection and Get OPLC Information ( Make sure you are communication with the PLC ) When that answers back correctly, Click on the Middle ICON in the Communication - PC Settings Box -- Yellow Sun with Red Dot Install Operating System Click on Check and follow the prompts, The process may decide to install just 1 file, of maybe all 4 files. Just click and let it do it's work -- takes several minutes. There is a progress bas that shows what is happening When done, it lets you know, Then reset and download your program. DanT Quote Link to comment Share on other sites More sharing options...
