prichter Posted September 9, 2013 Report Share Posted September 9, 2013 Dear Support Staff, Via the VisiLogic it is possible to reset and initialize the device under the Communication & PC setting tab. Is there any solution to do it via the PCL program? History: Ater entering the correct password to a pre-selected name, the program loads another display. The asterisks appeared as inverse characters and indicated that the password entering is possible. Pressing the ESC button, or power up the module I could get back to the name selection, but after selecting the same or another name the passord fied cannot be modified anymore. Reason(?) I suppose, that is why the HMI password pointer still keeps the last position of the password field. Executing the Initialization & Reset via VisiLogic the PLC works well as in the beginnig. Purpose: I am gonig to write a simple solution to force the user to log in again in case of an certain external events. Thanks for your kind answer in advance. Best regards Peter Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 10, 2013 MVP 2021 Report Share Posted September 10, 2013 You can Initialize & Reset from Visilogic if you are online with the PLC by going to Connection / Communication & OS / then 2nd tab over. Not sure about initialization, but you can reset the PLC with ladder logic by forcing SB300 high. Quote Link to comment Share on other sites More sharing options...
prichter Posted September 12, 2013 Author Report Share Posted September 12, 2013 You can Initialize & Reset from Visilogic if you are online with the PLC by going to Connection / Communication & OS / then 2nd tab over. Not sure about initialization, but you can reset the PLC with ladder logic by forcing SB300 high. Thanks. Formerly I tried the SB24, which initializes too. That works, but it seems that it is not very "beautiful" solution, because it forces the PLC to initiate all system variables. I wanted to initiate anly the required ones. The SB300 does not solve the problem unfortunately. I tried to use the display refresh SB (SB31) which did not solve the problem too. Only the SB24. Thanks again, BR Peter Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted September 13, 2013 MVP 2014 Report Share Posted September 13, 2013 This seems like a simple problem, and as you suggest, a full system initialisation is a "brute force" solution. There is probably one value that needs to be manually cleared to give you what you want, or possibly some small change to your logic. If possible, post your code. Quote Link to comment Share on other sites More sharing options...
prichter Posted September 17, 2013 Author Report Share Posted September 17, 2013 (edited) This seems like a simple problem, and as you suggest, a full system initialisation is a "brute force" solution. There is probably one value that needs to be manually cleared to give you what you want, or possibly some small change to your logic. If possible, post your code. Hi Simon, Thanks for your kind reply. Probably the "brute force" initiates the display registers. It was better to send you the whole file as attached. Find it! Thanks for your kind help in advance. Kind regards, Peter GELIN_tolto9.vlp Edited September 18, 2013 by prichter Quote Link to comment Share on other sites More sharing options...
prichter Posted September 26, 2013 Author Report Share Posted September 26, 2013 Hi Simon, Thanks for your kind reply. Probably the "brute force" initiates the display registers. It was better to send you the whole file as attached. Find it! Thanks for your kind help in advance. Kind regards, Peter Dear Simon, Have you managed to conern with described problem? I attached the file formerly. Thanks for your kind help in advance. Best regards Peter Quote Link to comment Share on other sites More sharing options...
