Not enough space to extract package
Joe Tauser
I downloaded 1.2.5 to play with over the Christmas holiday.  When I tried to install it I got a message stating "There is not enough space on drive C:\ to extract this package."
I used WinZip to manually extract the Unilogic Install file to a directory and was able to run the program from there.
This appears to be a problem with InstallShield.  The Creators will probably want to have a look at this.
