gstrack Posted May 6, 2014 Report Share Posted May 6, 2014 Hi There, I get an error message when I try and install the latest VisiLogic software v9.7 on my laptop, which is running Windows 7 Enterprise 64-bit. UAC is already disabled. The error message pop-up is: "VisiLogicSetp_9_7_Build_00.exe is not a valid Win32 application." I've tried to run as Admin and to install at C:\ without success. Anyone else encounter this issue and/or knows how to resolve it? Cheers, Gavin Quote Link to comment Share on other sites More sharing options...
Alexander Posted May 6, 2014 Report Share Posted May 6, 2014 Gavin, It could be that the installation.exe file became corrupted during the download. Please remove this file and re-download the VisiLogic 9.7 installation file from our downloads page. If you continue to experience issues please send an email to support@unitronics.com Quote Link to comment Share on other sites More sharing options...
Nildo Posted May 27, 2014 Report Share Posted May 27, 2014 Hi , I get an error message when I try to open VisiLogic software v9.5.0 on my laptop, which is running Windows 7 Home Premium 64-bit. UAC is already disabled. The error message pop-up is: "14Invalid Tools collections index" and after open a file .vlp other error: "Run-time error '70': Permission denied " This last error causes close the program. I've tried to run without success. Anyone else encounter this issue and/or knows how to resolve it? Regards, Nildo Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted May 27, 2014 Report Share Posted May 27, 2014 Hello Nildo, Try to solve the problem as follow: Open the task manager and close VisiLogic. Delete the file Current_OPLC.udb from: C:\Program Files\Unitronics\Unitronics VisiLogic_C\Data\DB . Disable Windows UAC and run VisiLogic If the problem still occur: Backup you projects and delete all the files related to Unitronics installations. • Erase the “Unitronics VisiLogic_C” folder from- C:\Program Files\Unitronics • Erase the “Unitronics” folder from- C:\Program Files\Common Files. • Perform Windows update and restart the PC • Log-on as administrator • Save the setup file on your desktop and make sure that the installation file is not blocked (Right click on the file>Properties) If yes, just click on the unblock button: Install VisiLogic. If software opened properly, Go to the properties of VisiLogic shortcut and under compatibility ticked verify the Privilege Level “Run this program as an administrator”. I hope it helps… Quote Link to comment Share on other sites More sharing options...
Nildo Posted September 24, 2014 Report Share Posted September 24, 2014 Thank you Mr. R.Mosed, i solver this problem with this procedures. Regards, Quote Link to comment Share on other sites More sharing options...
Nildo Posted September 25, 2015 Report Share Posted September 25, 2015 Hi There, I get an error message when I try and install the latest VisiLogic software v9.7 on my laptop, which now is running Windows 8 Enterprise 64-bit. Could you help why this problem too. Thank you Nildo Quote Link to comment Share on other sites More sharing options...
