greml1n Posted August 18, 2014 Report Share Posted August 18, 2014 Sorry for all the questions but now I am having trouble with email. Trying to get email to work crashed UniLogic a couple of times and generated the screen to send the report to Unitronics. UniLogic shut down after this so I was not able to generate the report to Unitronics. It looks as though some changes were made to UniLogic since the email Webinar was made. One thing I noticed was that there is no members of the "send email struct" as there were on the webinar: send success, send failure, status. Might that be part of my problem? besides ignorance Quote Link to comment Share on other sites More sharing options...
Alexander Posted August 18, 2014 Report Share Posted August 18, 2014 Which version of UniLogic are you using? The struct, Send Email, should still be created as soon as a new email is created within the configuration window. This includes the bit tags for success and fail as well as an integer tag for the email send status. Quote Link to comment Share on other sites More sharing options...
greml1n Posted August 18, 2014 Author Report Share Posted August 18, 2014 Using 1.7 Rev 62 Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 19, 2014 Report Share Posted August 19, 2014 Ok, let get some info: * Are you opening an exising project or creating a new one? * If its an old project, in what version it was created? * Can you give a specific scenario that causes the crash? Quote Link to comment Share on other sites More sharing options...
greml1n Posted August 19, 2014 Author Report Share Posted August 19, 2014 I am opening an existing project that was created using 1.7.62. It is not crashing now but I still can't get email to work. As I said earlier, there are no members of the send email struct. I'm not sure if I'm missing something. When it did crash once I got the message about generating a report for Unitronics and two other times Windows had a problem with Unilogic and shut down the program Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 19, 2014 Report Share Posted August 19, 2014 Well, it seems that the missing members are the problem. Can you try and create a new project and see if the members are there? Quote Link to comment Share on other sites More sharing options...
greml1n Posted August 19, 2014 Author Report Share Posted August 19, 2014 sure I will try that tonight when I get home, I'll let you now Quote Link to comment Share on other sites More sharing options...
greml1n Posted August 19, 2014 Author Report Share Posted August 19, 2014 Got home early. When I open a new project the send email struct members are there. When I open my existing project the email struct members are not there Quote Link to comment Share on other sites More sharing options...
Saragani Posted August 20, 2014 Report Share Posted August 20, 2014 Ok, and you are sure that the defective project was created using version 1.7.62 (not with earlier version and then upgraded)? You've said that UniLogic crashed when you first added the email. Maybe that caused the struct to be made without any members. Can you please send the project to the support, and ask them to forward it to me? 1 more thing, go to: %programdata%\unitronics\unilogic\temp\ Do you see a foder called ErrorData? Hopefully, if UniLogic did not crash after the crash you've mentioned, and hopefully that the file were not erased, can you please send the Zip, or the other files in that folder to the support (also forward to me)? Thanks Quote Link to comment Share on other sites More sharing options...
