MVP 2021 Flex727 Posted March 20, 2015 MVP 2021 Report Share Posted March 20, 2015 If the battery goes low in a V570, I can change it without disrupting the running PLC. However, the system bit SB8 appears to remain high until the PLC is power cycled. Is there any other way to reset this bit? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted March 22, 2015 Report Share Posted March 22, 2015 Hello, Unfortunately there is no any other way to reset this bit System bit 8 will be reset at power up. Quote Link to comment Share on other sites More sharing options...
