Paul Rylatt Posted April 23, 2015 Report Share Posted April 23, 2015 Is there any plan to integrate Ethernet/IP into the Vision line or will that be for Unistream only? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted April 25, 2015 MVP 2021 Report Share Posted April 25, 2015 Is there any plan to integrate Ethernet/IP into the Vision line or will that be for Unistream only? Hi Paul, Uhhhmmmm. Isn't it there already? Or perhaps you are asking something different? Please elaborate. Aus Quote Link to comment Share on other sites More sharing options...
Alexander Posted April 27, 2015 Report Share Posted April 27, 2015 Currently only the UniStream can utilize the EtherNet/IP protocol. The Vision series can use an Ethernet connection for various protocol communications such as Modbus IP, Open Protocol, TCP Raw, UDP, etc but cannot use the proprietary EtherNet/IP protocol. There are not any current plans to implement this within the Vision Series and we would recommend using the UniStream or a third party converter. Quote Link to comment Share on other sites More sharing options...
