OLAF Posted October 14, 2015 Report Share Posted October 14, 2015 I have been using under Visilogic the feature to "Hide" and "Marking" screen buttons. Like this I could hide the button, if its function should not be active (not only disabled, but really "gone") - display it again, when its usage was alllowed and even use the "marked" button as feedback, if for example its initiated function was active. 1 button - 3 functions. In Unilogic I am now at the point to use binary image elements, but I am only managing to get one of the two functions implemented at once: hiding the button using two images (one blank images), but then without the marking view, while a "marked" binary image cannot be hidden anymore. Question: is there a combined "mark" and "hide" function existing in Unilogic? Thanks a lot in advance! Olaf Quote Link to comment Share on other sites More sharing options...
Alexander Posted October 15, 2015 Report Share Posted October 15, 2015 There is a way to hide the element using the Tag: Visibility attribute in the properties window. This will perform the same task as "hide" in VisiLogic. There is not a marking color, though the disable color can be modified instead of the standard grey. Another way to draw attention would be to place a simple colored rectangle behind the element that could be hidden by default, but then enabled which would put a border around the element or change the background color if the background of the element is transparent. Quote Link to comment Share on other sites More sharing options...
OLAF Posted October 20, 2015 Author Report Share Posted October 20, 2015 Thanks a lot Alexander! Still a pity...was a nice feature to combine several output functions within one configuration. Olaf Quote Link to comment Share on other sites More sharing options...
yehudag Posted November 2, 2015 Report Share Posted November 2, 2015 Hi Olaf There are a "State Machine Button" element. There you can add many buttons styles (foreground color, other text styles, and Actions) as you wish to one element. Maybe this will help you. yehuda Quote Link to comment Share on other sites More sharing options...
