OrdosDeviator Posted April 2, 2016 Report Share Posted April 2, 2016 Hello, I am a newcomer in Unitronics and I met a ladder feature I can't understand. This is from U90Ladder examples: I can see 2 coils in one line. I tried to repeat this, and this doesn't work: So, the question is: how does it work in 1st case and how can I use this technique correctly? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
s.pratt Posted April 4, 2016 Report Share Posted April 4, 2016 Hello, Are there any other coils for O4 in your program? It may be an issue due to the sequence of operations. Please ensure you only use one coil per operand (Output/Bit) in your program. Quote Link to comment Share on other sites More sharing options...
dan Posted April 4, 2016 Report Share Posted April 4, 2016 Hi OrdosDeviator, The example for the second should work, assuming this is the only coil for the output. Is there another coil for the output? Is so, the coils will conflict, and the last coil will control the state. Please feel free to post your project and I can test. Dan. Quote Link to comment Share on other sites More sharing options...
OrdosDeviator Posted April 4, 2016 Author Report Share Posted April 4, 2016 Yes, there was the same coil in a string after. It explanes everything, thank you. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted April 4, 2016 MVP 2021 Report Share Posted April 4, 2016 Also, if that ladder rung is in a subroutine, make sure the subroutine is being called by the Main routine. Quote Link to comment Share on other sites More sharing options...
