SD Card explorer to remember file locations.
Ausman
Hi all,
asking if we could possibly have SD Card Explorer remember the previous location for local file saving.  I store my logged data files to a particularly "deep" area of my folders, and it's a right pain in the butt to start from scratch each time at the Browse for Folders window and have to click your way to the relevant area before you can proceed.  click click scroll click scroll click scroll click scroll click ohh for pete's sake!
I know I could cut and paste from a simpler spot, but that's not the point.
cheers,
Aus
HI Saragini,
sorry for the delay.  This appears to work ok, but is confusing as it doesn't show the files in a folder when you reach it.  But it does remember the location.
Can't remember if the old one showed files or not at the end folder, and too busy at present to change it all back again to see.
For now, thanks for relieving my clicking!
cheers,
Aus
Hi, the old one was showing only the the folders (Like a tree), and as much as I remember, Windows also showing this dialog (at least from Windows vista or 7 and onwards) for selecting a folder.
The button at the bottom of the window has it written "Select Folder", and in my opinion, this dialog is nices, since it also gives you the option to enter a path at the typing area, by either typing it, or by pasting from clipboard.
Plus, it also supports "Favorites" and "Libraries" from Windows (No more browsing from C:\ root to "Desktop" or "My Documents")
  • 2 years later...
HI @Saragani,  (and all)
you might recall messaging about this all working ok.
Somewhere between this Topic's successful resolution, and the latest version available for download, this ability has been lost.   I needed to download a copy a while back, and in using  .66 it appeared to not be remembering locations.  I did some checking once I had a bit more time available and the ability has indeed gone missing.
And whilst you are fiddling with it's code on the download site, can you please make the program open to the previous window size, instead of maximised every time?
cheers, Aus
2 hours ago, Saragani said:
Can you check it on a different computer?
Will do, but it will take a few days to do this unless someone else tries first.  Just FYI, both the laptop and the main system I did this on are still on 7-64 Pro.  And you guys are likely off the air until Sunday anyway, right?
cheers,
Aus
  • 4 months later...
@Saragani
Hi Saragini, I didn't really get a chance to report back until now, which has just been accumulating knowledge through general use on various O/S.  I can confirm that it doesn't remember last location on program startup on any of the O/S I use.  But if you close then reopen the program without rebooting, the location is retained.  Once there is a reboot involved, it doesn't.
Something else to perhaps change as well, which has annoyed me for some time.  If you use the Favorites tab in connection type, it actually seems to be using it's OWN favorites list, not the .evb used elsewhere.  A quick search on my C only reveals the one .evb, so the program must be using it's own method/file system for saving this info.  It is also annoying that if you simply highlight the required favorite as a double click, or single click and OK, this DOESN'T select those properties like you would expect.  You have to use the "Load Connection from Selected Row" star to do so.  This is so unlike normal usage it is easily forgotten....like I just did a moment ago.....and took a while to remember this quirk!
cheers,
Aus
