stanthe1man Posted October 2, 2016 Report Share Posted October 2, 2016 Please could someone explain how I can display a 0-10v input signal as a pressure output:- 9.1v = 1000mb to 1.0v = 5.5 x 10-5mb ? I am using 1210 with latest Visilogic. My ladder programming skill is quite basic but I have managed to control and HMI a full high vacuum pumping system but need to display the vacuum levels in scientific notation. Any help would be great. Many thanks Stan Quote Link to comment Share on other sites More sharing options...
Kikis Posted October 5, 2016 Report Share Posted October 5, 2016 Hello, If the pressure is linearly proportional to the analog input voltage, then you could use linear interpolation formula and floating point registers (MF). Floating registers are also known as real numbers and it's the best way to deal with fractions. Since the linearization function within Visilogic can't be used for MF registers, you have to do it step by step using simple mathematical functions. LINEAR INTERPOLATION FORMULA: Y = ( ( X - X1 )( Y2 - Y1) / ( X2 - X1) ) Where, X1,Y1 = First co-ordinates X2,Y2 = Second co-ordinates X = Target X co-ordinate Y = Interpolated Y co-ordinate If your 0-10V analog input is 12 bit (0-4095) then, X=Current analog input value linked to an MI X1=409 X2=3726 Y1=0.000055 Y2=1000 Y= Pressure result displayed on the screen Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 7, 2016 MVP 2021 Report Share Posted October 7, 2016 First, which module part number are you connecting the input to? I think you may have a bigger problem with the resolution of the A/D converter in the module. Our highest resolution is 14 bit, which means you get 2^14 or 16384 counts to play with. You've dialed the span down to 9.1 V to 1.0 V, so you'll get a smaller fraction, assuming you're using one of these inputs: 1.0 V = 1638 counts = X1 9.1 V = 14909 counts = X2 Total span = 13271 counts Your high end value is 1000 (Y2), so the best you can get if the low value is 0 (Y1) is 0.07 mb per count. In other words, trying to read more than one decimal of precision accurately is unobtainable. You can feed the output of the Linear block into an interpolating equation as Kikis points out, but everything past the first decimal will be meaningless. Joe T. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted October 7, 2016 MVP 2021 Report Share Posted October 7, 2016 +1 to Joe's post. But seeings how you are working with a vacuum system, you really only need to display things once it gets down to certain levels. eg my refrig gauges only display digits below 500 microns. It appears that you can change the outputs of the sensor to various vacuum levels, so you might be able to get the figures you need by reducing the span to very high vacuum zones. If you can do this, but also do need to display vacuum through the entire range, then use 2 sensors with settings to suit and automatically switch between them. cheers, Aus Quote Link to comment Share on other sites More sharing options...
