MattP_Mac Posted February 2, 2017 Report Share Posted February 2, 2017 I am working with VisiLogic 9.8.31 and using a V570 controller. I am unable to find/load the following modules in HW Configuration: IO-D18-R08, EX-A2X, and V200-19-ET2. Is this an issue with outdated software? I just downloaded it a few weeks ago. I'm not sure if I need to be physically connected to the modules in order to recognise them. The actual PLC and modules haven't arrived yet, Just doing some initial setup. Any suggestions would be appreciated - this is my first time using Unitronics equipment and software. Thanks! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 2, 2017 MVP 2021 Report Share Posted February 2, 2017 There's no entry needed for the EX-A2X. It's assumed you have one, as nothing works without it. The V200-19-ET2 is the Ethernet Card. This is initialized in the ladder logic - read the Help on Card Init. The proper part number for the digital module is IO-DI8-R08. This is in there. Joe T. 1 Quote Link to comment Share on other sites More sharing options...
Cam Posted February 2, 2017 Report Share Posted February 2, 2017 (edited) Visilogic assumes that the EX-A2X is present if you are using expansion I/O, so you don't need to add it into the hardware config. The IO-DI8-RO8 is listed with the IO-DI8-TO8 and will show as IO-DI8-TO8/RO8 in the hardware config screen under I/O Expansions. The V200-19-ET2 is a card that the PLC recognizes when you plug it in it's not part of the hardware config. You do have to make sure that the card and sockets are initialized, and a PLC name is set in in the ladder(recommended to be done with SB2 on power up) in order to use the V200-19-ET2. Joe beat me to it Edited February 2, 2017 by Cam 1 Quote Link to comment Share on other sites More sharing options...
MattP_Mac Posted February 2, 2017 Author Report Share Posted February 2, 2017 (edited) Thanks for the help, apologies for the basic questions. I do not have that option for IO-DI8-R08. I have IO-DI8-R04 and IO-DI8-T08 and EX90-DI8-R08 which are the closest. Thanks Cam Edited February 2, 2017 by MattP_Mac problem solved Quote Link to comment Share on other sites More sharing options...
Cam Posted February 2, 2017 Report Share Posted February 2, 2017 (edited) Screen Shot of what you need to select. Cheers. Edited May 11, 2017 by Cam Picture removed 1 Quote Link to comment Share on other sites More sharing options...
