ORSO2001 Posted February 15, 2017 Report Share Posted February 15, 2017 Dear All, After that I changed few tags reference in few screen objects (string) that were already present and I done the "compile" I have had the errors below: : Error in Line: 0, Column: 0, Message: _Init_Operands.cpp In function 'void _Init_Operands()' _Init_Operands.cpp: Error in Line: 331, Column: 885, Message: cannot convert 'volatile Queue_t*' to 'volatile MngArray_t*' in argument passing arm-none-eabi-g++: Error in Line: 0, Column: 0, Message: _Init_Operands.o No such file or directory : Error in Line: 0, Column: 0, Message: arm-none-eabi-g++ fatal error no input files : Error in Line: 0, Column: 0, Message: compilation terminated. : Error in Line: 0, Column: 0, Message: compilation terminated. : Error in Line: 0, Column: 0, Message: :: Someone can help me to fix this? I am using the version 1.18.60 thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 16, 2017 Report Share Posted February 16, 2017 Try build-all if that doesn't solve the project, then send it to us. I want to know how b it happened? Did you n change a data table indexed to a FIFO? Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted February 16, 2017 Author Report Share Posted February 16, 2017 Dear Saragani, In my project I inserted a FIFO data table but it was already present from time and I never had this problem; as I wrote after that I change some tag reference in some screen objects I have had this error during the compile...however following your suggestion " Did you change a data table indexed to a FIFO? " I checked the details of the FIFO data table and I found that the "data type" was changed from FIFO to index....I set again FIFO and the error is disappeared...I am quite sure that I have not changed this... anyway thanks for the help Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 16, 2017 Report Share Posted February 16, 2017 OK, but even if the type got somehow changed to FIFO, you should have not got the error. I'll be glad to get the original project that reproduces the problem (if you still have it). Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted February 16, 2017 Author Report Share Posted February 16, 2017 Dear Saragani, As I wrote the problem seems fixed after that I set back the data table from index to FIFO. If having my project, I saved a copy with the issue, can "help" you to check what is happened is not a problem for me...let me know how I can send this to you. Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 17, 2017 Report Share Posted February 17, 2017 yes, please send it to our support Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 19, 2017 Report Share Posted February 19, 2017 OK, I see the problem: The table is defined as DTI, while the linked struct is defined as FIFO. This should not have happened. I'm currently looking for a scenario that can cause it. If you have any insights or you can reproduce it, then it can help. Thanks. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted February 19, 2017 Author Report Share Posted February 19, 2017 Dear Saragani, I create a new project (totally empty); I create a Struct with only one variable (UINT8); I create a FIFO data table ...during a compile I have the same error. I try to install again the Unilogic...and I let you know. Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted February 19, 2017 Author Report Share Posted February 19, 2017 I installed again the Unilogic and seems ok but I don't understood one thing...when I create the first Struct I can choice any name that I want ("FIFO" or "fifo" included)...as second, or if I try to rename the first one, I can't choice "FIFO" or "fifo" (red labeled)...why? Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted February 19, 2017 Author Report Share Posted February 19, 2017 dears, other thing that I have "found" is that if I open the GLOBAL varialble list and, I point one of these, I push the right mouse button the list close itself ...If I well remember with the previous versions a pop up menu should be open with some options (like search in the ladders)...? Same for the tags on the HMI objects. maybe the downloaded file is corrupted? Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 20, 2017 Report Share Posted February 20, 2017 19 hours ago, ORSO2001 said: I installed again the Unilogic and seems ok but I don't understood one thing...when I create the first Struct I can choice any name that I want ("FIFO" or "fifo" included)...as second, or if I try to rename the first one, I can't choice "FIFO" or "fifo" (red labeled)...why? Because at some point, when you create a Data Table, UniLogic creates a struct or an enum named FIFO, and it detects a conflict (2 structs or tags with the same name). 16 hours ago, ORSO2001 said: dears, other thing that I have "found" is that if I open the GLOBAL varialble list and, I point one of these, I push the right mouse button the list close itself ...If I well remember with the previous versions a pop up menu should be open with some options (like search in the ladders)...? Same for the tags on the HMI objects. maybe the downloaded file is corrupted? I'm not sure I understand. Are you talking about the Auto-Complete? Meaning, then you click on a tag assignment, you get a list of all legal possible tags that you can enter to that assignment. Are you saying that in previous versions, you could have right clicked on any of the items in that list and select "Search"? If not, then please explain. If yes, then I don't remember that it ever existed. You can right click on any tag assignment and search for the tag that appears in the expression (You can also press Ctrl+F for find or Ctr+H for replace and select the find&replace tags and search/replace scope) Quote Link to comment Share on other sites More sharing options...
ORSO2001 Posted February 20, 2017 Author Report Share Posted February 20, 2017 Dear Saragni, about first point I understood. About second point...The "issue" was caused because was selected "auto hide" for the menus on the bottom; then if I select GLOBAL the tags list appears and if I pushed the mouse right button, on a tag, the menu disappear; I removed "auto hide" and let "dockable" then now when I push the mouse right button an a tag I have the pop up menu that include "find tag: xxxxx"...sorry...maybe this setting was changed after the new installation of Unilogic. thanks Quote Link to comment Share on other sites More sharing options...
Saragani Posted February 20, 2017 Report Share Posted February 20, 2017 OK, I understand, You are correct, the pane gets hidden. Since UniLogic 1.18, you can undock panes out of UniLogic (so you can work with multiple windows). This required using a different control for the panes management. The pane closes since it looses focus, so thanks for pointing it out. One workaround for this issue is left clicking on a row on the grid first. Then if you right click, the context menu opens without hiding the pane. I'll open a bug report for this issue. Quote Link to comment Share on other sites More sharing options...
Cara Bereck Levy Posted February 21, 2017 Report Share Posted February 21, 2017 14 hours ago, Saragani said: You are correct, the pane gets hidden. Since UniLogic 1.18, you can undock panes out of UniLogic (so you can work with multiple windows). This required using a different control for the panes management. There is a Help Topic: Customizing your UniLogic Environment. It has a .gif that shows how to float panes Quote Link to comment Share on other sites More sharing options...
