darknesspic Posted July 7, 2017 Report Share Posted July 7, 2017 Dear All I using V280, in HMI when I put the variable(key entry) on the HMI, the SI250 will automatically numbering. So, do I want to re-order SI250 again? Thank you Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 8, 2017 MVP 2023 Report Share Posted July 8, 2017 What are you trying to do with SI 250? Link to comment Share on other sites More sharing options...
darknesspic Posted July 9, 2017 Author Report Share Posted July 9, 2017 When I place the key entry on the HMI and then (First time)First variable(variable10) would be SI250=0 (Second time)Second(variable11) variable would be SI250=1 (Third time)Third(variable12) variable would be SI250=2 ...something like that But I want to re-order the variable again to (variable12) going to be SI250=0 (variable10) going to be SI250=1 (variable11) going to be SI250=2 Is it possible? Please advise. Link to comment Share on other sites More sharing options...
Vidmas30 Posted July 9, 2017 Report Share Posted July 9, 2017 Hi, Darknesspic, Try to delete them from HMI and place back in order you need. Link to comment Share on other sites More sharing options...
AlexUT Posted July 9, 2017 Report Share Posted July 9, 2017 Hi, You can re-arrange keypad-entry variables. Use "Variables Tab Order" Change variables order as you need. Is this what you need? Link to comment Share on other sites More sharing options...
darknesspic Posted July 11, 2017 Author Report Share Posted July 11, 2017 On 7/9/2017 at 1:53 PM, Vidmas30 said: Hi, Darknesspic, Try to delete them from HMI and place back in order you need. ^^Yes I use this way at the time, thank you. On 7/9/2017 at 2:03 PM, AlexUT said: Hi, You can re-arrange keypad-entry variables. Use "Variables Tab Order" Change variables order as you need. Is this what you need? ^^ My Visilogic doesn't has this feature(my visi is 9.8.31 build0), please advise Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted July 11, 2017 MVP 2023 Report Share Posted July 11, 2017 Are you sure you have V280 selected in the Hardware Configuration? Link to comment Share on other sites More sharing options...
