JJ263 Posted July 13, 2017 Report Share Posted July 13, 2017 I have a bunch of USMP files (trend data). Not all have ended up as zipped CSV files. What format are the USMP files? Looks like XML in the header, but I can't crack the encoding used for the actual data. Is there a file converter available for USMP files? Link to comment Share on other sites More sharing options...
Saragani Posted July 15, 2017 Report Share Posted July 15, 2017 The actual data is a binary data, and there is a set of tools called UniStream Data Converters Suite which can convert the USMP to PDF or to CSV. 1 Link to comment Share on other sites More sharing options...
JJ263 Posted July 16, 2017 Author Report Share Posted July 16, 2017 Took a bit of finding (had to use a google search targeted on the Unitronics web site, as site itself does not seem to have a usable search function ?? ). For future reference https://unitronicsplc.com/Download/SoftwareUtilities/ It does the job, thanks, although the converter does not seem to be able to access or output to anywhere but the /onedrive/documents folder on my Windows 10 machine. You can select different directories, but it ignores your selection and drops back to that default. Probably a Windows 10 "thing". Link to comment Share on other sites More sharing options...
Saragani Posted July 17, 2017 Report Share Posted July 17, 2017 Try running the software as administrator. Maybe windows is preventing writing to protected directories. Link to comment Share on other sites More sharing options...
Wiseguy Posted January 31, 2020 Report Share Posted January 31, 2020 I did a test with a Trend and the Create CSV bit on It looks like 3 file types are generated on the SD card: .usmp, .csv and .csz.zip files Is there anyway to just have the .csv file created and not the zip file? Link to comment Share on other sites More sharing options...
ControlsGuru Posted November 30, 2020 Report Share Posted November 30, 2020 Is there a current link to this tool? I have the same issue. Link to comment Share on other sites More sharing options...
AlexUT Posted November 30, 2020 Report Share Posted November 30, 2020 Hi, Enter Unitronics Web Site http://www.unitronicsplc.com Point to Software and select UniLogic from drop-down menu Scroll down page. Expand Here it is. Link to comment Share on other sites More sharing options...
