embc Posted January 17, 2018 Report Share Posted January 17, 2018 Hi all, I have a Unitronics v1040 display screen that is acting up. It froze briefly so I powered down and then when I turned it back on it only stays on an error screen. Any thoughts? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted January 17, 2018 MVP 2021 Report Share Posted January 17, 2018 Pls post a shot of the screen for those in the know to help better. cheers, Aus Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 18, 2018 MVP 2021 Report Share Posted January 18, 2018 Search the VisiLogic Help file for "Bootstrap". Try some of the options there to see if you can recover. You might need to re-download the O/S if you can establish communications. Quote Link to comment Share on other sites More sharing options...
