Rob Miller Posted February 1, 2018 Report Share Posted February 1, 2018 I'm brand new to UniLogic so it's probably right in front of me and i can't find it. How do i get a string of the date & time? I see the RTC Date and Time system tags that consist of the parts but i need to get a strings of mm/dd/yyyy and hh:mm:ss Also, is there a way to concatenate strings? I'd like to save a data table to a SD file based on a user input name, ascii date, ascii time (name_mmddyyyy_hhmmss) Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted February 1, 2018 MVP 2021 Report Share Posted February 1, 2018 There is a UDFB that helps with this. I can't remember where to find it so I'll just attach my copy here. RTC to ASCII.ulle 1 Quote Link to comment Share on other sites More sharing options...
