I am new to unitronics Visi logic software. i am using V1210 controller at site. i need to do an modbus 485 communication between an GE controller an V1210 controller here GE controller is an master and unitronics V1210 as an slave i need to sent all my MI and MB used values to GE controller. In this case i need to write my data to GE PLC i searched in unironics there is read block is present but write blocks are not there.
how can i write my data to GE plc please guide me on this if you have any reference logic for the same please share with me. i already created logic for configure the modbus 485 communication and Port initialization logic.
thanks in advance.
You have a master/slave issue here.  And the magic word for looking at what you want is FBs/Modbus/Preset.
You'll either have to have the GE poll (often) the V1210 slave periodically to get the updated MI & MB values, or implement a change in the slave/master relationship so that the 1210 can send them, using "Preset", as the Master, to the GE.  The GE may have a function where it can act as Slave/Master, which would make this easy.  Examples exist showing how to change the 1210 from master to slave, but labelled as "V130_Modbus_Master_Slave_switch".
Other forum members might have a workaround, but to me this is the essence of the issue.
cheers,
Aus
