Fabios Posted March 22, 2011 Report Share Posted March 22, 2011 Hi, i control a V570 from remote with Remote Operator, and when is necessary a ceck software plc. But this 2 operation is not possible to do in the same time. Is any chance to control with Remote Operator and connet with visilogic? Fabio Quote Link to comment Share on other sites More sharing options...
Saragani Posted March 22, 2011 Report Share Posted March 22, 2011 Yes, if you are using 2 different ports. For example, COM1 on Remote Operator and COM2 on Visilogic... or Ethernet on one of them and serial port on the other, or 2 Ethernet connections to different ports on the PLC. Quote Link to comment Share on other sites More sharing options...
Fabios Posted March 22, 2011 Author Report Share Posted March 22, 2011 2 Ethernet connections to different ports on the PLC. Yes i want 2 ethernet connection. But Remote Operator connect only with 20256 port. If i change, 20258 or other, no connect Quote Link to comment Share on other sites More sharing options...
Saragani Posted March 22, 2011 Report Share Posted March 22, 2011 The PLC is configured with port 20258? You have 4 ethernet ports on your PLC. You can configure each of them to be either master or slave, and you can select the port it will use. Quote Link to comment Share on other sites More sharing options...
Emil Posted March 22, 2011 Report Share Posted March 22, 2011 Port 20256 is default setting for Socket 1. The default setting for Socket 3 is port 20257. You can use these two ports to connect to VisiLogic and Remote Operator without performing Socket Init. Of course - you can add module Socket Init and change settings for each Socket - including port number. Quote Link to comment Share on other sites More sharing options...
Fabios Posted March 22, 2011 Author Report Share Posted March 22, 2011 Port 20256 is default setting for Socket 1. The default setting for Socket 3 is port 20257. You can use these two ports to connect to VisiLogic and Remote Operator without performing Socket Init. Emil, if i understand well, i can connect with Remote Operator or Visilogic with 20256 and 20257 port without performing Socket Init. OK, but with 20256 work both visilogic, both Remote Operator. With 20257 no work nothing. What i forget to do? Quote Link to comment Share on other sites More sharing options...
Fabios Posted March 22, 2011 Author Report Share Posted March 22, 2011 i must do NAT with 20257 port on router!!!!! Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted March 23, 2011 MVP 2021 Report Share Posted March 23, 2011 You have to specify in the Remote Operator software communication configuration table that you want to use port 20257. Otherwise it will default to 20256. Joe T. Quote Link to comment Share on other sites More sharing options...
