KevinS Posted May 29, 2018 Report Share Posted May 29, 2018 Hi All, Is there a way on the HMI to have a button that toggles both an MB and the text that appears on the button? I am using a V350 and tried it with the Binary Text object. I can set the Link and Touch entries to the same MB, but when I turn on the toggle function, Visilogic tells me that it has to remove the Touch property. Thanks, Kevin Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted May 29, 2018 MVP 2021 Report Share Posted May 29, 2018 If you check the "Toggle" box it automatically becomes a touch button. Joe T. Quote Link to comment Share on other sites More sharing options...
KevinS Posted May 29, 2018 Author Report Share Posted May 29, 2018 The message from Visilogic made me think that it was removing the touch property, but I just tried it and downloaded it and the touch property is there. Thanks, Joe Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted May 29, 2018 MVP 2021 Report Share Posted May 29, 2018 Yeah, that warning message is a bit misleading, but what they mean is that any element's touch property is always momentary contact. The toggle checkbox creates the toggle feature, so it conflicts with the touch property. Quote Link to comment Share on other sites More sharing options...
