Guest Hervé Posted July 2, 2018 Report Share Posted July 2, 2018 hello, I would like to know how to display the BACnet on unilogic. I manage to make the link with an automaton but after I am blocked to visualize it on the supervison. Thank's Quote Link to comment Share on other sites More sharing options...
EduMarg Posted August 16, 2018 Report Share Posted August 16, 2018 Hello, The GW-BAC1 is an external, high performance Building Automation multi-protocol gateway that has been preprogrammed for enabling Unitronics products to various building automation protocols. These protocols include BACnet MS/TP and BACnet/IP. Configuration for the various protocols is done via Unitronics configuration tool UniBACnet Configurator. To configure it you have the UniBACnet configurator. this configurator is a tool provided Unitronics that allows the user to create the configuration file for the GW-BAC1 easily. Once created, the configuration file should be downloaded to the GW-BAC1 in order to enable it to communicate with the Unitronics PLC. The UniBACnet configurator can be launched from both the VisiLogic and UniLogic programing applications Tools menu. This tool will configure the BACnet getaway as BACnet master and modbus Slave. If you wish to have the getaway act as BACnet slave and modbus master the configuration file should be change manualy before downloading it to the device. The RS485 connection is a strait forward RS485 connection between the PLC and the getaway. You may also connect the PLC via Ethernet port. The Getaway supports Modbus RTU and Modbus Ethernet and Bacnet MS/TP and Bacnet IP. You may have any combination of them. I have attached some examples to use with UniStream PLCs. Bacnet examples for Unilogic.zip Quote Link to comment Share on other sites More sharing options...
SoCalJim Posted October 11, 2018 Report Share Posted October 11, 2018 Do you have an example project where the PLC is the slave/server? We have a Crestron that's supposed to control us via BACnet. Quote Link to comment Share on other sites More sharing options...
SoCalJim Posted October 13, 2018 Report Share Posted October 13, 2018 I tried to manually modify the config file to swap the roles but it didn't work. Quote Link to comment Share on other sites More sharing options...
SoCalJim Posted October 15, 2018 Report Share Posted October 15, 2018 Which sections would I swap here? //================================================================================ // // Common Information // Bridge Title CN0864 Unitronics v1.00a //================================================================================ // // Data Arrays // Data_Arrays Data_Array_Name,Data_Array_Format,Data_Array_Length DA_AI_U16,UInt16,1 //================================================================================ // // Client Side Connections // Connections Adapter,Protocol,IP_Port N1,Bacnet_IP,47808 //================================================================================ // // Client Side Nodes // Nodes Node_Name,Node_ID,Protocol,Adapter myController,0,Bacnet_IP,N1 //================================================================================ // // Client Side Map Descriptors // Map_Descriptors Map_Descriptor_Name,Data_Array_Name,Data_Array_Offset,Function,Node_Name,Object_Type,Object_Instance,Property,Scan_Interval Temperature,DA_AI_U16,0,Rdbc,myController,AI,0,Present_Value,2s //================================================================================ // // Server Side Connections // Connections Adapter,Protocol N1,Modbus/TCP //================================================================================ // // Server Side Nodes // Nodes Node_Name,Node_ID,Protocol,Address_Type Unitronics_Modbus_Node,255,Modbus/TCP,ADU //================================================================================ // // Map Descriptors // Map_Descriptors Map_Descriptor_Name,Data_Array_Name,Data_Array_Offset,Function,Node_Name,Address,Length,Data_Type SMD_DA_AI_U16_1,DA_AI_U16,0,Passive,Unitronics_Modbus_Node,1,4,Input_Register Quote Link to comment Share on other sites More sharing options...
SoCalJim Posted October 15, 2018 Report Share Posted October 15, 2018 In the provided example "unistream_070_Bacnet_TCP", there's a global of type "Modbus Remote Slave". When I try to add another global, "Modbus Remote Slave" doesn't appear as a type option. Since my PLC is going to be the slave, should there be a type "Modbus Remote Master"? Quote Link to comment Share on other sites More sharing options...
