Khi Posted September 21, 2018 Report Share Posted September 21, 2018 Hello everyone, Well,the question is how i can store 300 hours or 200 hours and run the machine from the hmi. The timer in this plc is 99 hours max. Best regards Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 21, 2018 MVP 2021 Report Share Posted September 21, 2018 There are many ways to do this. One way is to create a 1 hour timer and use it to increment an MI or Counter. Quote Link to comment Share on other sites More sharing options...
Khi Posted September 21, 2018 Author Report Share Posted September 21, 2018 Thank you flex727, Would you please show me how to do this in the ladder ? I just started to programming codes to plc's. Best regards Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 21, 2018 MVP 2021 Report Share Posted September 21, 2018 Well, it would depend on exactly what you're trying to do. Quote Link to comment Share on other sites More sharing options...
Khi Posted September 21, 2018 Author Report Share Posted September 21, 2018 I am trying to run a process. From the hmi i enter the time for example :100 hours or 400 hours at the end its stop automaticly. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted September 21, 2018 MVP 2021 Report Share Posted September 21, 2018 1 Quote Link to comment Share on other sites More sharing options...
Khi Posted September 21, 2018 Author Report Share Posted September 21, 2018 Thanks a lot for your help Best regards Quote Link to comment Share on other sites More sharing options...
Khi Posted October 13, 2018 Author Report Share Posted October 13, 2018 On 9/21/2018 at 9:35 PM, Khi said: Thanks a lot for your help Best regards Hey flex727 How can i reset this timer manually? Best regards Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 13, 2018 MVP 2021 Report Share Posted October 13, 2018 It's deceptively simple- Set MB 26 to call the reset and let this rung reset the timer and the calling bit. Joe T. Quote Link to comment Share on other sites More sharing options...
Khi Posted October 13, 2018 Author Report Share Posted October 13, 2018 On 9/21/2018 at 9:35 PM, Khi said: Thanks a lot for your help Quote Link to comment Share on other sites More sharing options...
