Didier 62 Posted September 24, 2018 Report Share Posted September 24, 2018 Bonjour, Quelqu'un a t-il déjà piloté ou connecté un moteur PAP sur un système SAMBA? Merci, Didier Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted September 24, 2018 MVP 2021 Report Share Posted September 24, 2018 6 hours ago, Didier 62 said: Bonjour, Quelqu'un a t-il déjà piloté ou connecté un moteur PAP sur un système SAMBA? Merci, Didier Translation: Hello, Has anyone ever piloted or connected a PAP engine on a SAMBA system? thank you, Didier OK, what's a PAP engine? Joe T. Quote Link to comment Share on other sites More sharing options...
John_R Posted September 25, 2018 Report Share Posted September 25, 2018 well, this of course piqued my interest, and I had to google it seems to refer to a little backpack motor/prop used by para-gliders to power their flights, perhaps this is the reason the OP used the term piloted? and it seems Samba is a brand of ultra-light aircraft.... my search also brought up an interesting read about the Papp engine. things that make you go Hmmm...... https://www.infinite-energy.com/iemagazine/issue51/papp.html Quote Link to comment Share on other sites More sharing options...
