andrewcclark0@gmail.com Posted November 16, 2018 Report Share Posted November 16, 2018 I have 2 flow meters in a project they are model:FS-8800H 3.0-100.0 Liters per minuet I am using a v700 HMI with the a V200-18-E3XB snap in module I'm having trouble linearizing the data so that it shows the correct value. Any help would be much appreciated, and I can provide any additional information needed. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted November 16, 2018 MVP 2021 Report Share Posted November 16, 2018 That appears to be a digital pulse flowmeter. You will need to write some code to sum the pulses and divide by the time. This link may help you get started:https://control.com/thread/1239744023 1 Quote Link to comment Share on other sites More sharing options...
andrewcclark0@gmail.com Posted November 16, 2018 Author Report Share Posted November 16, 2018 I'm not very familiar with Visilogic or programming to be honest, can I do this just by the math functions and then connecting it to the linearization function? Thanks for your help Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted November 16, 2018 MVP 2021 Report Share Posted November 16, 2018 You might want to look at this post and read the entire topic . It might be of use to you, or at least point you in the right direction. It all depends on how many pulses you get per given flow amount. Cheers, Aus 1 Quote Link to comment Share on other sites More sharing options...
