meysam Posted January 11, 2019 Report Share Posted January 11, 2019 what is this? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 11, 2019 MVP 2021 Report Share Posted January 11, 2019 I moved this to the appropriate forum. The message is telling you that the PLC is stopped. Normal mode is Run mode. If reboot (power cycle) doesn't help, go into INFO mode to see if you can change the mode to Run. Do you know that there is a program in the PLC? You may need to check or replace the battery and re-load the program. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted January 11, 2019 MVP 2021 Report Share Posted January 11, 2019 As we see - it is broken screen on the top left. Sensor on display maybe is "touched by self" - so this screen mode is activate. Or as Flex727 say - it is battery issue. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted January 11, 2019 MVP 2021 Report Share Posted January 11, 2019 1 hour ago, kratmel said: As we see - it is broken screen on the top left. I didn't notice that. Great spot! Quote Link to comment Share on other sites More sharing options...
