Pradeep Mane Posted March 19, 2019 Report Share Posted March 19, 2019 Hello, What are the possible ways to Download the Program through Ethernet from remote location. My OPLC is V700 Thanks!! Quote Link to comment Share on other sites More sharing options...
MVP 2022 Flex727 Posted March 19, 2019 MVP 2022 Report Share Posted March 19, 2019 Moved post to the correct forum. You use VisiLogic, not Remote Access to download a program. To answer your question, you can download a program remotely through Ethernet exactly the same way you do locally through Ethernet. All you need is a connection through the internet, whether by port forwarding, VPN, or any other method that gives you a network connection. 1 Quote Link to comment Share on other sites More sharing options...
Cam Posted March 20, 2019 Report Share Posted March 20, 2019 Another option is to send a compressed file to a SD card installed in the PLC and then trigger it to update the program from there. We typically do this if we are not having a tech on site(sales reps don’t count). As we have a copy of the current program in the SD card the rep can test and if there’s a problem they can revert back to the previous program and NOT rely on the Ethernet connection to stay up. 1 Quote Link to comment Share on other sites More sharing options...
