fbojan Posted August 19, 2019 Report Share Posted August 19, 2019 Hello I have Jazz JZ20-R10 and modem Cinterion BGS2T. Everything works fine until I update O/S JZ from V2.41 to V2.42 and to V2.44. PLC can`t established communication to modem. SMS: Initialization Failed Register SI180 = 3 When I return O/S to V2.41, everything is OK. What should I do? Best regards. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted August 19, 2019 MVP 2021 Report Share Posted August 19, 2019 Why are you updating the O/S? Quote Link to comment Share on other sites More sharing options...
fbojan Posted August 19, 2019 Author Report Share Posted August 19, 2019 Becouse I update the program U90Ladder and then always when I download the program to Jazz program offer me to download the OS. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted August 19, 2019 MVP 2021 Report Share Posted August 19, 2019 Why did you update U90Ladder? Quote Link to comment Share on other sites More sharing options...
fbojan Posted August 19, 2019 Author Report Share Posted August 19, 2019 I bought new laptop and I download new U90Ladder. No reason. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted August 19, 2019 MVP 2021 Report Share Posted August 19, 2019 fbojan, Flex is heading into explaining that you have fallen into the trap of "always having the latest", when in fact if it isn't broken, don't change it! (This is the reason why the Vision system has Version Swapper, but such a thing doesn't exist for U90.) You need to use/download the U90 version you wrote the original program with and also use that to change the OS to the correct one. The download area lists these under Previous Versions. Many people have an area of their program that specifies exactly what they used at the time. Some have it showing on screens, some in a hidden location that is consistent b/n all jobs. cheers, Aus Quote Link to comment Share on other sites More sharing options...
fbojan Posted August 20, 2019 Author Report Share Posted August 20, 2019 Ausman, I already did it. I just wanted everyone to know about the problem. Thanks. Quote Link to comment Share on other sites More sharing options...
