MVP 2022 Flex727 Posted July 28, 2020 MVP 2022 Report Share Posted July 28, 2020 I'm using UniLogic 1.28.34 and can see no way to add a string variable to the body of an email. Am I missing something? If not, anyone know of a workaround? Quote Link to comment Share on other sites More sharing options...
Clark Posted July 31, 2020 Report Share Posted July 31, 2020 Hello, I think you can insert variable into your message with the tool box, in the construction of your mail. Use Number Variable or liste of text will help you. Quote Link to comment Share on other sites More sharing options...
Patko Posted June 1, 2021 Report Share Posted June 1, 2021 On 28. 7. 2020 at 21:01, Flex727 said: Používam UniLogic 1.28.34 a nevidím žiadny spôsob, ako pridať reťazcovú premennú do tela e-mailu. Uniká mi niečo? Ak nie, vie niekto o alternatívnom riešení? Hello Flex, unable to insert string into email body. When composing an email, "string variable" is missing, but alternatively use "Subject" in the email. Using the "insert to string" function, it is possible to compose the final string and use it as a "subject". Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 1, 2021 Report Share Posted June 1, 2021 Hi Flex727, Follow article: UniStream Send Email with Indirect Text (use SD text file)https://support.unitronics.com/index.php?/selfhelp/view-article/unistream-send-email-with-indirect-text Or upgrade to last version and it will be supported. B.R. Quote Link to comment Share on other sites More sharing options...
