PLC Reset and Initialize & Reset
To make it a bit simpler: Reset is a soft boot - exactly the same as power cycling without having to remove power. Nothing is lost.
Initialize & reset erases the values in all the memory registers (MB, MI, ML, etc). It does not affect any other aspect of the PLC (program, data tables, etc are retained).
Of course if there are any power-ups in the program, the initialized registers will obtain those values immediately after the reset.
  • Like 1
