hugojose Posted August 24, 2020 Report Share Posted August 24, 2020 Am trying to upload/download from a old V130-33-TR20. I get and "Overflow, error 6". Tryng downloading new OS, it goes as far as trying to delete files on PLC, and then quits, not being able to communicate with PLC unless turned off and back on. Can go no further. Any suggestions?? Thanks. Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted August 24, 2020 MVP 2021 Report Share Posted August 24, 2020 Please see this and this Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted August 24, 2020 MVP 2021 Report Share Posted August 24, 2020 Also possibly the old chestnut....did you install Visilogic using right click run as admin and also ensure the visilogic.exe is set to run as administrator as well? cheers, Aus Quote Link to comment Share on other sites More sharing options...
hugojose Posted August 25, 2020 Author Report Share Posted August 25, 2020 Ausman, and Kratmel, Thanks for your replies. Yes am running Visilogic as Administrator. And by the way, have also an even older V120, and I can communicate, program, download, upload to it, using same computer, software (the latest), and same cable with no problems. .......am interested in restoring everything to factory settings, but not sure if there's such thing on these Unitronics. Am going to look into taking battery out as some one mentioned in link provided by Kratmel. Quote Link to comment Share on other sites More sharing options...
hugojose Posted August 25, 2020 Author Report Share Posted August 25, 2020 OK, Don't know exactly what did it, but first removed battery. After 1/2 hour reinstalled it and powered it up. I could tell still had old program which did not expect. Went into Communication and OS and reinstalled OS and Boot program and took it. .....after that was able to upload program that was there w/out error. Looks good. Thanks guys for your help. Quote Link to comment Share on other sites More sharing options...
